joshuajim wrote:
joshuajim wrote:
BenK wrote:
Add that the compression ratio of the gasser isn't high enough to attain the
temps needed to ignite without a spark
Plus the rate of burn (not explosion on regular gasoline compression
ratios...but on one high enough for self ignition...it *WILL* become
an explosion) for gasoline is too fast for compression ignition. A
gasoline engine with compression ratios high enough to self ignite
'can' do it...but not for long
..and I thought the PRE-IGNITION was ignition before the spark occured! Hmmm... guess I was wrong.
Ahh... another politician. Just deflect and deny.
At least not a mumbojumbo man...maybe a bit higher level, but never
the less another 26:4-5
Continual amazement of how well marketing works down there
