Brox
Apr 22, 2014Explorer
Markiemark32 wrote:
Should be on "driver-side", right near the axles, I use to scoot in right in front of the wheel or reach in between the two wheels.
It is a single hoses coming out of lining with a screw on cap.
Markiemark
Ok so its the hose thats sticking down about 1-2" in front of the axles with a white plastic cap thats kinda of hard to get off? So is the one in the back driverside thats got a red fitting with white cap the hot water tank then? And do i need to drain those seperate or will the hot water tank drain when i'm draining the fresh tank?
44,066 PostsLatest Activity: Apr 15, 2026
