Charlie_D_
Jan 08, 2018Explorer
There is an item called Speedi-sleeve available at bearing companies. Has a small flange to allow a surface to drive the sleeve on and then is removed. Provides a new seal surface. Used them in the chemical industry and they work well. They will need the size of the shaft which would be the same as the I.D. of the seal. I have found that oil will weep between the O.D. of the seal and the ID. of the housing. Pematex should solve that problem.
44,066 PostsLatest Activity: Apr 16, 2026
