LIKE2BUILD
Jan 08, 2018Explorer
Cummins12V98 wrote:
You may want to consider the QUALITY of seal you used! I have filled to the bottom of the hole on all 4 RAM's I have owned.
The replacement seals I used last summer were CarQuest brand, which obviously is made by someone else and put in their box. Typically I've had very good service from their parts as I've used CarQuest for 30 years.
The original seals that failed would have been the OEM. I'll do some checking to see who makes the CarQuest branded seals.
Good to know you fill to the bottom without issue. This whole deal has me baffled. I'm really wondering if there is a problem with the check valve in the vent hose. I'm going to look into that just to be certain I'm not building up pressure inside the axle.
KJ
44,066 PostsLatest Activity: Apr 16, 2026
