LIKE2BUILD
Jan 08, 2018Explorer
Charlie D. wrote:
There is an item called Speedi-sleeve....I have found that oil will weep between the O.D. of the seal and the ID. of the housing. Pematex should solve that problem.
Right, I've also used speed-sleeves, I was just wondering if anyone might know the part# for the correct sleeve to use. Unfortunately I don't have the luxury of time for this repair. The truck is currently my daily driver so I need to have all parts on-hand so I can do the repair and be back on the road the next day. I don't have time to tear down, take measurements, order parts, then wait for them to come in.
With as much oil as I see in the inside of the wheel I'm guessing it will be hard to see exactly where the oil is coming from. But you're right, some permatex around the seal OD certainly won't hurt. I didn't see any obvious imperfections on the axle tube (seal ID surface) so I would have thought the new seals would fix things up. I've not had problems previously with oil leaking around the OD of seals but the extra protection using a sealant is a good idea.
KJ
44,066 PostsLatest Activity: Oct 04, 2013
