jus2shy
Jan 09, 2018Explorer
OP, I hope this helps you. This is for my 2013.
Axle Ratio
3.73, 4.10
Ring Gear Diameter
292 mm (11.5 in.)
Ring Gear Backlash
0.13 - 0.18 mm (0.005 - 0.007 in.)
Pinion Torque To Rotate - New Bearings
1.69 - 2.82 N·m (15 - 25 in. lbs.)
Pinion Torque To Rotate - Original Bearings
1 - 2 N·m (10 - 20 in. lbs.)
Total Torque to Rotate - New Bearing
3.4 - 5.6 N·m (30 - 50 in. lbs.)
Total Torque to Rotate - Original Bearing
2.8 - 5.1 N·m (25 - 45 in. lbs.)
Fill Level - From Bottom of Fill Hole
6 mm (1/4 in.) ± 6 mm (1/4 in.)
all torque values are the name, then NM, then FT-Lbs.
Fill Hole Plug
32
24
Differential Cover Bolts
40
30
Bearing Cap Bolts
281
207
Ring Gear Bolts
237
175
Axle Flange Bolts
129
95
Adjuster Lock Bolt
25
18
And what I find for installing an axle seal
1.Install outer hub bearing cup with Installer 8961 and Handle C-4171 .
2.Install inner hub bearing cup with Installer 8153 and Handle C-4171 .
3.Pack bearings with the appropriate wheel bearing grease.
4.Install rear bearing and install new grease seal with Installer 8963 and Handle C-4171 .
5.Slide hub on the axle tube and install front bearing into the hub.
6.Install hub bearing nut with Socket 8954 (1) and tighten with torque wrench (2) to 30 N·m (22 ft. lbs.) while rotating the hub.
7.Back off nut about 30° and align next hub nut key slot with axle tube key slot and install locking key.
NOTE:
End play should be 0.025-0.25 mm (0.01-0.001 in.)
8.Install retainer ring (1) with ring end in the key slot (2).
9.Install new axle shaft gasket and install the axle shaft.
Axle Ratio
3.73, 4.10
Ring Gear Diameter
292 mm (11.5 in.)
Ring Gear Backlash
Fill Hole Plug
32
24
40
30
Bearing Cap Bolts
281
207
Ring Gear Bolts
237
175
Axle Flange Bolts
129
95
Adjuster Lock Bolt
25
18
NOTE:
44,066 PostsLatest Activity: Apr 16, 2026
