LIKE2BUILD
Feb 13, 2018Explorer
I'd like to bring this back to the top.
I've ordered the Unitized seals and the seal installer tool. At $30/each it's worth the price to use the tool designed for the part to avoid a failed install.
So next question. The Torque King description says the seal is press fit into both the hub and on the axle. So the tool presses into the hub, but what about onto the axle tube? Is it just using a block of wood on the end of the hub and driving it on? I plan to use gasket maker on both the hub and axle so the pressed surfaces have some 'extra incentive' to not leak.
I'd appreciate any extra advice on this install. I'm certainly going to chase down the axle vent too and make sure it's clear and not building pressure.
KJ
KJ
44,066 PostsLatest Activity: May 18, 2026
