Calicajun
Mar 15, 2015Explorer
14" To 15" TT Wheels
Other than being sure there is enough clearance to use 15" tires instead of the stock 14" tires. Is there anything else I should be aware of that could cause a problem?
Campfire Time wrote:
You really don't get an increase in capacity. More often than not your axle is rated to be right at the edge also. So unless you are upgrading your axles too, bigger tires will just give you a nice warm fuzzy, lighten your wallet, and do nothing to increase your capacity.
In other words, before you spend a dime, check your axle rating and see if there is reserve capacity over and above what your current tires are rated for.
