DesertTracker
Jul 22, 2016Explorer
Changing From 14" to 15" Tires and Rims
In order to add a weight capacity reserve on my tires I am thinking of going from ST205/75r14C to ST205/75r15D. Lots of capacity reserve gained with this change. It seems simple enough; all size specs are the same except diameter is +1" so I will lose 1" between the tandems and 1/2" clearance from top of tires to fender wells. I have the needed clearance. Before I spend all those dollars at Discount Tire Direct for the wheel and tire upgrade I thought I had better check: is there anything else I need to consider? Thanks for any advice and help.
