Calicajun
Mar 15, 2015Explorer
14" To 15" TT Wheels
Other than being sure there is enough clearance to use 15" tires instead of the stock 14" tires. Is there anything else I should be aware of that could cause a problem?
Campfire Time wrote:
You really don't get an increase in capacity. More often than not your axle is rated to be right at the edge also. So unless you are upgrading your axles too, bigger tires will just give you a nice warm fuzzy, lighten your wallet, and do nothing to increase your capacity.
In other words, before you spend a dime, check your axle rating and see if there is reserve capacity over and above what your current tires are rated for.
spike99 wrote:bigjoey38 wrote:
I have looking at a few TT. some say get the double axle much better then single. Is the correct and is a single doable?
If exact same trailer came in both double or single axle, I'd buy the "double axle" trailer every time. Double axle rides smoother, less chance of blow out and more braking power. Win-win of many different fronts.
TxTwoSome wrote:
You can find 14" in D range at tire rack,Northern tools and etrailer.com I have been looking myself.
