CalicajunExplorerMar 15, 201514" To 15" TT WheelsOther than being sure there is enough clearance to use 15" tires instead of the stock 14" tires. Is there anything else I should be aware of that could cause a problem?
rbpruExplorer IIMar 16, 2015I would double check the axel rating. It is often the weak link.Usually the combined weight ratings of the two tires are a bit, not a lot, more than the axle.At least this is true for both my TT and TV.
Related Content14" or 15" Wheels?14" to 15" tiresChanging from 14" to 15" wheels and tires on a TT14" to 15" tires...Any Advantages???Changing From 14" to 15" Tires and Rims
