Other than being sure there is enough clearance to use 15" tires instead of the stock 14" tires. Is there anything else I should be aware of that could cause a problem?
You'll get an increase in capacity going from 14" D's to the 15D's so I think it's a good move. As always, I suggest Maxxis ST tires for 15" applications.
