H4X0R
May 02, 2014Explorer
15 amp fuse keeps blowing when hooked to generator
I have a 2014 Keystone Fireside 26t, when I plug it in to generator it blows a 15 amp fuse in the TT that controls the use of the 12v battery. I checked the wiring (white neg, black pos) and it is and has always been connected correctly. After it blows I unplug the generator disconnect the negative from battery and put a new fuse in. After I put the new fuse in I connect negative back in and lights, water pump work fine off the battery alone, battery is 3/4 charged. But after doing so I turn off all lights, pumps etc... And turn back on generator. I let it stay on for about 2-3 minutes then plug in the 30 TT power cord. By the time I get back inside the TT the fuse has blown again? If anyone has any tips or solutions to my problem I would really appreciate it!
