Tvov
Jun 30, 2020Explorer II
Jebby14 wrote:
i have a 2015 s'crew. i hook it to the safety chain loop with its own carribeaner. if i manage to sepporate the entire hitch assembly from the truck i have bigger problems.........
there are several places for a sepporation to happen downstream from the hitch that in most all situations will be the case first.
I think my 2008 F250 is similar - there is a metal loop under the bumper that I hook the breakaway cable to. I believe it is actually attached to the frame of the truck, I'd have to go out and check. There are two loops on the frame of my hitch for the safety chains.
Mickey, have you gotten under the rear of your truck to see if there is a loop or something you can use? Assuming there is, it may be tucked up and back a bit.
44,071 PostsLatest Activity: Sep 17, 2026
