FishOnOne
Aug 12, 2014Nomad
4x4ord wrote:
I think it makes total sense to compare the F450 to the 3500 Ram. If I am wanting a truck to tow 30,000 lbs this is what these two manufacturers recommend. The engines and transmissions are designed different that to say they need to have identical rear end ratios seems foolish to me. I actually tow 30,000 lbs quite regularly with my 2011 srw and it seams to handle the weight well enough for my expectations. I have heavier trucks that I could use but my personal preference is to use the pick up for lighter loads like that.
I agree... And also would like to add Chrysler's engineers specified the rear end ratio probably to match the power band of the cummins engine.
44,066 PostsLatest Activity: Mar 14, 2015
