captnjack
Aug 31, 2014Explorer
BurbMan wrote:captnjack wrote:
Where are you getting your info? I believe your numbers are low. More like 2900 pounds for my 2002.
I don't think so. My 01 weighs 6700 lbs at the scale with full fuel and me in the driver's seat. Subtract that from the GVWR of 8600 lbs and you get 1900 lbs payload. I would love to know how you determined yours has 2900 lbs of payload.
No I have not towed in the Western mountain but have pulled many long grades in the Smokies including several in/around Asheville. I went a few miles up a 20% grade on a PA secondary road to get to a CG. Nothing ever caused the trans temp to get above 200.
To the OP, if you zoom in on a pic of the vehicle, look at the pillar between the rear door and the long side window, it will say LS or LT with "Autoride" below it. The LT came standard with leather, but you could get it as an option on the LS. The rear captain's chairs and rear audio were options regardless of trim level.
Inside the glovebox there is a sticker that has a series of 3 character codes, what GM refers to as Regular Production Options (RPO) codes, and that tells you everything the vehicle was built with. It looks like this:
Here's what mine mean:
RPO Description
AG1 Adjuster FRT ST Power, Multi-Directional, Driver
AG2 Adjuster PASS ST Power, Multi-Directional
AJ1 Windows Deep Tint, All Except W/S and DRS
AN3 Seat FRT, Individual (Non BKT)
AS3 Rear Seat +Suburban/Utility
AT5 Seat Rear CTR, Folding
AU0 Remote Function Actuation - Keyless Entry (Domestic)
A31 Window Power Operated, All Doors
BVE Steps Runningboard, Side
B30 Floor Covering Carpet
B35 Covering Rear Floor Mats , Carpeted Insert
B39 Covering Floor Carpet, Load Floor
B58 Covering Floor MAT, FRT and RR, Carpeted Insert
B71 Wheel Opening Flares
B85 Molding - Body Side , Exterior, Bright
C36 Heater Auxiliary
C49 Defogger Rear Window, Electric
C6P GVW Rating 8, 600 LBS/3, 900 KG
C68 HVAC System Air Conditioner FRT, Auto, Electronic Controls
C69 HVAC System Rear Air Conditioner
DF5 Mirror, I/S R/V LT Sensitive, Compass, O/S Temp Display
DK2 Mirror, O/S LH and RH, Remote Control, Electric, Heated, Color
DK7 Interior Roof Console, Custom
DR2 Mirror O/S LH and RH, Remote Control, Electric, Heated Light Sensitive, Manual, Folding, Color
D07 Console Front Compartment, Floor, Custom
GT5 Axle Rear 4.10 Ratio (DUP With GT8)
G80 Axle Positraction Limited Slip
JH6 Brake HYD Power, 4 Wheel Disc, 9, 900 LBS
KC4 Heavy Duty Engine Oil Cooling
KG8 130 AMP Generator
KNP Heavy Duty Transmission, Cooling System
KUP Throttle Control Electronic
K34 Cruise Control, Automatic, Electronic
K47 Air Cleaner High Capacity
L18 Engine Gas, 8 CYL, 8.1L, MFI
MT1 Transmission - 4-Speed Auto W/Elect Controls H.D. (Hydra - Matic 4L80 - E
NP5 Steering Wheel Leather Wrapped
NP8 Transfer Case - (Active) - Push Button Control, 2 Speed
PY0 Wheel - New - Aluminum - 16 X 6.5
QIZ Tire All LT245/75R16/E BW R/PE ST TL OOR 12OQ
SLT Equipment Chevrolet 'LT' Sales Package
T96 Fog Lamps - Front
UE1 Communication System Vehicle, G.P.S. 1
UG1 Opener Garage Door, Universal
UP0 Radio - AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, Compact Disc, Auto Tone Control, Clock, and ETR (Radio Will Not Snap Fit Into IP- No Attaching Fasteners, CD Will Be Remote Mounted Other Than the IP)
UQ3 Speaker System Performance Enhanced Audio
UY7 Wiring Harness Truck Trailer, HD
VB3 Bumper Rear Step, Chrome, Impact Strip
VG3 Bumper Front Impact Strip
VR4 Trailer Hitch Weight Distributing Platform
V54 Roof Mounted Luggage Carrier
XHH Tire Front LT245/75R16/E BW R/PE ST TL ALS 120Q
YD6 Spring Rear, Base Equipment
YE9 Convenience Package Comfort and Decor Level #3
YHH Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120Q
ZHH Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120Q
ZW9 Base Body or Chassis
Z55 Chassis Package Bi-State Real Time Damping
Z82 Trailer Provisions Special Equipment, H. D.
U 9539 is the paint color.
If the seller will snap a pic for you I have the complete list of what all these codes mean. I also have the full factory service manual if you need help with anything.
Numerous sources list curb weight at about 5700 lbs. I haven't been to the scales with mine so I can't say what is exactly what.
