Gold's avatar
Gold
Escalade/Denali or Suburban 2500
I’m considering buying a 2010 Escalade/Yukon XL Denali or a similar year Suburban 2500.
I currently have a great running 2003 Suburban 1500 5.3L 285hp autoride which I’ve upgraded with stiffer z51 springs and has fresh GM autoride shocks. I recently obtained a 20 foot v-nose toy hauler, I’m guessing the weight of the loaded trailer (and people/cargo in the suburban) is 6,000 lbs. Fortunately it’s very level and stable when towing because I can’t have a WDH as the v-nose on the trailer prevents a WDH from being used.
My issue is that I simply run out of power with the Suburban. I can’t use cruise control on the highway as just the slightest incline (or even the wake of a truck) will cause the Suburban to gear hunt, and even when not using cruise control it’s hard to maintain 60 mph.
I’m considering either a 2010 Escalade ESV/Yukon Denali XL (both have 6.2L 402HP 1500 chassis), or a similar year Suburban 2500 which has the 6L 355HP 2500 chassis.
I’m more attracted to the Escalade/Denali as they are quite a bit less expensive and exponentially easier to find (and have a bigger engine and 47 more HP), but can it tow ‘as fast’ as the Escalade/Denali despite it having 47 less HP that I should consider it. Thank you in advance for your insight.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
