BenK
Sep 10, 2014Explorer
Going from 3.73's to 4.1's will have approx 10% more torque at the drive axles,
minus losses. That is how diff gearing works
I don't recommend adding a rear anti-lean (sway) bar to a vehicle that did not
have one from the OEM. If you do, make sure to increase the front bars rating
Otherwise it may create an over steering condition at the limits
For towing, that means a higher chance of jack knifing the setup during severe
maneuvers
We are talking about a 2500 Suburban, right?
The suspension & frame are already very stiff from the factory
For a 1500, yes will help, but key is to make sure the front bar is also increased
in stiffness
maneuvers
in stiffness
