hprince wrote:
Towing with 3/4 ton Ram Diesel, using Ezee Lift WDH with 12in shank,1000# Bars and double Ezee Lift friction sway bars. The question I had was has anyone used the 16in shank and have they had any problems with it. I have a LCI elec tounge jack that has a triangle base which makes it hard to rotate the jack, I have also been told that the head on the jack can not be rotated
The holes in the triangle jack bases are equal, you can install them rotated one hole either way.
I have moved jacks back by adding a c-channel cross member welded in just behind the coupler plate and mounting the jack through the new cross member.
It is far simpler to just use the longer hitch shank though.
