brulaz's avatar
brulaz
Worn hitch receiver/shank
After 22K miles with 1000-1200# tongue weight, and maybe the same number of miles with only 650# tongue weight, things are getting pretty loose at the hitch receiver.
The welds on the F150 MaxTow hitch receiver all seem good, but it's stretched up at the front and worn down at the rear. And the WDH shank (Equal-I-Zer 1400#) is showing wear at the same places. The pin hole is also getting elongated.
When I lift up the extended tension bars by hand, the ends of the bars move about 2". This affects my WDH settings; it looks like I now need to add another washer or two to get back to my original settings.
And it seems to be getting worse more quickly now. Maybe as it gets looser it wears more quickly.
- Is this normal wear and tear for these things ??
Anyway, guess it's time to replace the hitch receiver.
Or, another possibility would be to have a competent shop put together a 2.5" receiver, possibly just welding onto the old crossbar. And getting a new 2.5" shank from Equal-I-Zer.
- A 2.5" system should last longer, right ??
One worry about the 2.5" shank is it's weight.
I can barely handle the hitch head with 2" shank now.
- So any suggestions for getting a 2" system to last longer ??
