brulaz wrote:
hohenwald48 wrote:
I made a couple of these and they really work well to prevent movement and wear.
http://littleguy.vanillaforums.com/discussion/1051/roadmaster-quiet-hitch-for-2-trailer-hitches
You mean the Heavy Duty Hitch Clamp?
HD Hitch Clamp
Or the Roadmaster Quiet Hitch?
Roadmaster
Both of these can be configured to hold down the top of the hitch which is what I would prefer. Guess the Hitch Vise only grips from the side (thanks tll).
That HD Hitch Clamp looks quite solid.
Wonder how it would work with the upward forces of a 1200# WDH?
The ones I made are similar to the Roadmaster except I used 3/4" round bar above and below the receiver and joined them with 3/8" grade 8 bolts and I really tighten them down. No set screws to loosen or wear like the HD Hitch Clamp has.
I've done the weld bead trick before too. It seemed I had to redo that at regular intervals to keep it good and tight. I would usually add to much weld and then file it to fit.
