hprince wrote:
Towing with 3/4 ton Ram Diesel, using Ezee Lift WDH with 12in shank,1000# Bars and double Ezee Lift friction sway bars. The question I had was has anyone used the 16in shank and have they had any problems with it. I have a LCI elec tounge jack that has a triangle base which makes it hard to rotate the jack, I have also been told that the head on the jack can not be rotated
I think I did answer your question and said there were no concerns or issues. I didn't include it since it isn't germane, but I had the same WDH system as you albiet with a single friction sway bar on my first trailer with the extended shank for 25 years and well over 100K miles towing and now using the exact same shank since 2007 with my Equal-i-zer WDH system with the same non issues now approaching 25K miles towing.
Larry
