boogie_4wheel
Oct 28, 2014Explorer
You will most likely have an issue running the smaller 16" wheel; the reason for the larger wheel is for brake clearance (the larger the rotor, the larger the wheel for caliper clearance).
That pretty much sums it up, you should go to the 18" wheel. Nitto has a 17" tire with a 3450lb rating if you want to keep the wheels you have now (verify wheel weight capacity).
