VinsilExplorerSep 25, 201518" wheel options?Is there any options for a 18" wheel that has a 4k+ capacity? I'm not finding any and haven't found specs on factory Ram aluminum wheels but assuming they are rated lower.
SugarHillCTDExplorerSep 25, 2015Not directly answering your question, but I run Nitto Dura Grapplers rated at 3970#. I have them mounted on OEM GM 17" STEEL wheels.My thinking is any failure would be bending instead of an alloy wheel cracking.I keep the OEM tires mounted on OEM alloy wheels for winter (non-rv) use.But IIRC weren't Ram owners finding Hummer alloy wheels (rated at 4000#?) that would fit their trucks?
Related Content18" tire question - ANOTHER UPDATEWeight Distribution Shank....2.5" receiver end X 18" LongWheel bearing repacking5th Wheel took out rear windowadvice on 5th wheel hitch option
