S Davis wrote:
Did you guys have to do anything to your TPMS system to account for running the higher tire pressure? Also how much noise/rougher ride compared to stock, my truck is a daily drive that the wife drives.
Thanks for the info.
Stacey
I purchased the wheels, tires and TPMS all as a set, installed and ballanced, from Rickson Tires. You need a different TPMS sensor for the higher PSI. I've got the Continental HSR / HDR set up, the tires are more noisy than standard on some surfaces and the ride is stiffer due to the sidewll plys. I've also got an extra leaf spring set on the rear so I feel EVERYTHING. Mine's a daily driver also. But, when the truck is loaded it feels real nice going down the road. After a few thousand miles the tires seem to have broken in nicley, either that or I'm just getting used to the ride. :)
Also, I heard that the Vision wheels don't fit the GM 2008 or 2009 bodystyles, the offset makes them rub in the front wheelwells.
