Tamnative
May 27, 2015Explorer
B-n-B wrote:
If the are lug centric wheels then they should have self-centering lug nuts that fit into matching recesses in the wheel. Hub centric should have a flat surface on the wheel that mates to flush mounting lug nuts.
I know what the difference is between the two, The Fords are hub centric and need to be kept that way to work as it was designed.
You need the weight on the hub and the lugs hold the wheel in place.
They make rings to make up the difference for aftermarket wheels for this purpose.
