Tamnative's avatar
Tamnative
Question to all Vision 19.5 wheel users
I was doing my pre-camper load up tire pressure ,check lug nuts torque etc. when I came to 2 lugs that didn't seem right. I was not able to get them to spec's. As it turned out it appears that the shop that did my front end alignment over tightened the nuts to the point that they are almost 1/4" deeper than the rest and that is without getting them to torque spec's. I will be taking the truck back to the shop that did this tomorrow. These are brand spanking new wheels and tires and this is the only time that they would have been removed. I had checked the torque on them right after I got them and all was good then.I have had problems in the past with tire shops that is why I always check.
My question is what type of lug nuts did they use on your Vision wheels? Here is a link to the ones that they used on mine: http://www.visionwheel.com/accessories/
I didn't think it would be possible to bury a lug nut into a rim like this without snapping the lug.
Any other suggestions would be helpful as I we planned on leaving Thurs. of next week but it may not happen.
I forgot to mention that the part no. on the lug nut is 3809L
