HMS_Beagle
May 28, 2016Explorer II
It's kind of like Porsche hanging the engine out in the back trunk. Not a good idea, but you can get it to work. I wonder if GM has better engineering resources than Vision?
Rough calculation: 1" diameter by 3/8" thick (as estimated by the OP) is 1.17 sq in cross section, shear failure in cast aluminum 10,000 psi, so shear failure at 12,000 lbs, clamping force on 5/8-11 bolt torqued to 150 ft-lbs is 14,400. This is why I am suspicious.
