jimh406
May 08, 2013Explorer III
19.5s F, G, H - What are you running?
My tires are due to being replaced (age ~ 7 years). Yeah, I might be able to push it a while longer, but I'm working on a plan. I wondered if there many improvements in the last few years that I've missed.
I currently run Gs that are rated at 4500ish at max air pressure which is very good for hauling a TC.
Do you run F, G, or H? Are you running 225/245/265 other? Have you noticed a sway/stability difference between brands/sizes aif you have run other brands/types?
I wanted a mud/snow tire and chose the Hankooks because they were available. They have a very sharp edge which I think tended to make the wander a lot in grooved roads.
I've also thought about going up to 265 this time, and believe I have enough clearance for a 1 inch taller tire and 1/2 inch wider tire.
