donn0128 wrote:
Anything is fixable. How handy in woodworking are you? How much do you want to put into this project? Those are the questions you need to ask.
Agreed. "a little water damage" can mean anything. You could have a little water leak at the left rear corner and that water could drain down and travel to the front and rot the entire floor out in that area. Hidden water damage can be found in a lot of areas where it is not apparent or is far from the original leak.
Water is the biggest killer of trailers; not time.
