dvargas2040 wrote:
So in comparison to the Lightning which is similar to my truck in an updated form, the Lightning is about 18" longer and has a wheel base of 10" longer and a curb weight of 4670.  It can pull a 5000 pound trailer. My truck in stock form weighs 3100 pounds.  Since my truck is a little more beefed up I am guessing and hoping a tow weight of 8000 pounds would be OK.  We are reconsidering the turbo option and will just see what the Gear Vendors will do for us.
I think that is the point everyone is making.
A Lightning has:
-a 10" longer wheelbase (quite a bit in the car world)
-1500lbs more curb weight
-rated to tow 3-4000lbs less then your target
Your initial question mentioned a 9800lb trailer which is even heavier yet!
Now...it sounds like you will have plenty of power and brakes to do the job, and you can easily get it to tow level with the right springs, air bags, and a WDH. It will do it no doubt.
However you may find it is a stressful towing experience once cars and semi's are passing on the freeway or you get a good crosswind.
You can definitely try it out and decide...sounds like you will be building the truck either way!
