dvargas2040 wrote:
What I really want to know is, is there somewhere I can take my truck
that will test the pulling rate and tell me the maximum trailer weight I can pull? I'm not sure how Ford tests their trucks to determine how much trailer weight capacity can be used, but that's what I'm after. If anyone knows the answer that I seek, please reply.
For several years each manufacturer had their own tests and in the mid-2000's we were head long in the towing wars. Of course those claims always came with asterisks....i.e. which engine, cab, trim, 2X4 or 4X4...those all factored in to what the OEM claimed they could tow. They still do, but which tests were performed with various packages varied by manufacturer.
After 2010,
SAE- Society for Automotive Engineers proposed
SAE Standard J2807 to level the playing field so that consumers could have an apples to apples comparison for tow ratings. Of course each OEM wanted to make sure their interests were protected but it seems beginning in the model year 2015 the US Big 3
adopted the J2807 Towing Standard.
I found a link describing
SAE Standard J2807 for Towing Capacities. The kicker is SAE wants $74 to download the document. If you're dead set on pursuing this I'm sure you could get the document or search corners of the internet until you find the details. The next big question is once you have the info, would you be able to find a proving ground with the necessary equipment to conduct the test and establish a new GVWR and GCWR for your '56.
From your description of the truck it sounds like you have extensive fabrication skills. I'd say with all of your proposed mods to the truck it will be sufficiently capable of towing the trailer you suggested. As others have suggested retro trailers I have to say I'd go with that too. At minimum if you pulled an Airstream or an old Avion it would fit a little better as both of those have a very unchanged, retro look.
Good Luck.
Kevin
