Gdetrailer
Apr 29, 2020Explorer III
Serial number most likely was on the now missing trailer box, typically a sticker that was typically placed on the trailer box on the drivers side of the trailer.
Some manufacturers would stamp the serial number on the tongue A frame, some may have marked the axles..
Serial numbers and placement were not "standardized" into VINs on older trailers and often did not follow any real logic..
Depending on your states DMV, four digits can present a challenge to reregister and some states may require a brand new VIN to be generated.
So, I would hold off on making any permanent alterations (markings) until you check with YOUR local DMV, they will be a far better resource than using the Internet.
44,068 PostsLatest Activity: Jun 05, 2026
