westend
May 17, 2017Explorer
Now the question is, "is 34 pictures too many?"
Nope, the more-the-merrier. The resto thread in my signature line, The Cowboy/Hilton is 39 pages and has about 300 images. Along the way, I had many requests for even more pictures.
I don't know about you, but I've about had it with Photobucket. The ads and functionality are really starting to lack. I might migrate my albums over to Imgur. I'll need to check on space allowed.
This Forum has an app for posting images--Hosting app. It works well but I haven't tried it with multiple images. It will take an image from another website and migrates it to Imgur.
Two things maybe worth mentioning: If I was going to keep that overhead hanging bunk (I wouldn't need it), I'd fasten another piece or two of wider lumber under the ledgers that are existing. I camped in a vintage rig that had that pipe arrangement and it was risky as heck.
I'd bet you are going to be replacing some framing. Your diagnosis of a leaking roof edge trim is probably spot on. I pulled both wall side edge trims on my roof, resealed with plenty of the best sealants I had (the original butyl plumbing putty was shot) and installed a new vinyl screw cover. It leaked right away through a few screws. I ended up encapsulating the screw cover and edge trim with Eternabond Webseal tape. I've pressure tested the trailer, intermittently, and have no leaks under the edge trim or through the screws.
Please, keep your progress updated and as many images as you wish. This is better than reading a book. :D
