westend
Jul 02, 2017Explorer
Tip on that non-greasable zerk location: Spray into the greased cavity some penetrant--JB, PB blaster, etc. Run it like that so the joint flexes and the penetrant can break down the old grease. The next time you put your gun on the zerk, it will let the new grease push that old stuff out. This is easier than taking apart the spring set and has worked for me many times.
