AnEv942
Feb 27, 2015Nomad
Dave Pete wrote:
...I might mention something here. The tank materials are soft. They are made out of milk jugs...
Enjoying your thread(s). This comment though, you made about tank material seemed like an opportunity to ask about the grey tank support, and the battery 'tray' on top. It could be Im just not clear on how its working but as this progresses still leaves me wondering. Especially after seeing the picture of the batteries on top.
Its the single support mid of tank. Though the tank material is malleable, it can split. Maybe given the length and height it will be ok. Then picture of batteries on top brought it to the forefront again.
The weight (if tray actually setting on top) adding to the point loading at the mid tank support?
Most questions or puzzlement, wait long enough and you addressed (ie. the perfectly placed knot on rear structure). This one just kinda buggin me?
Dave Pete wrote:
...I've tried in past to Teflon tape these types of joints and haven't been happy with the results. I much prefer the feel and result of brush on pipe dope for these tank fittings...
In all the pictures, the different cans of glue etc have no problem jumping in front of the camera, however the pipe dope seems to be camera shy. As you didnt mention only asking. Not sure on the tank material but the PVC threaded connections, regular pipe dope not intended specifically to be used on plastic threads can lead to failure, NON pressure less likely. Just curious and for other readers. I dont want to side track, threads and sealants can lead to a whole topic on its own.
44,056 PostsLatest Activity: May 04, 2014
