Today I'm shifting back into "Waste Water". The pre-outfitting of the galley area is coming along nicely. Yesterday over there, we did the top drawer dividers, as just one of the things going on behind the galley scenes.
Another of the things going on behind there is the waste water subject of the galley sink drain, waste, vent. The aspect of that I want to cover today is a continuation of my previous post here - regarding the copper pipe segment that comes out from behind the cabinet face, turns a couple corners (like the "magic bullet theory"), and disappears once again behind the fresh water cabinet scenes.
It was time to try my hand again at sweating copper. I don't often do that.
My Dad taught me how to sweat copper, and over the years I've had a little experience with it. New pipe and fittings are always easier to do a good job than used stuff. One of the secrets is that everything needs to be very clean, at least where the solder goes.
Sometimes you can get leaks where there was previous solder or a nick or some other imperfection in the joint surfaces, especially when using other than new. In this case, I had some used pipe, but all new fittings. Of course after the first try, if a second time is needed to correct a leak for example, now you have used parts! So far, that hasn't happened.
I have found 1/2" is easier than 3/4". I've never done anything but those two sizes. Now here I go with 1.5". I was a little nervous.
Was my propane torch going to be hot enough? Was I going to remember the steps while under way, including wiping the joint once done for a nicer look? Was the smoke alarm going to go off (and it did)? These fittings aren't cheap, and I could hardly destroy them, but success at first would be easier than a second or third try.
The first thing to do was place the hole in the galley face.
Having previously marked the hole, I ran a simple hole saw into the wood and removed the plug.
Then a simply barrel sander with the Dremel tool to slightly enlarge the diameter to fit the pipe.
I ended up with this. Far enough from the wall to allow the thickness of the planned wall covering, and far enough from the chrome flange on the range to keep from cutting into it, or touching it. Even a slight fraction of an inch separation between metals looks much more professional to my eye than does the two metals touching.
This is the test fit, before solder.
And it's look from a distance.
Here you see the end of the coupler - no pipe extension yet. This is where the joint enters the fresh water cabinet below the fridge and on top of the notch built into the fresh water cabinet partition face. From here I could determine how long to make the extension pipe. I made a poor decision, I cut the extension too short for optimal. After all was said and done I had forgotten to "plumb" the currently unfastened portion of the face wall and it wasn't pushed far enough back, or to the right from this angle.
Here you can see the extension in place at the coupler.
The main reason for cutting it shorter at all was for installation. This picture shows what I had planned. First insert the longer end into the galley face. Then swing the shorter end up into a notch I would cut in the fresh water cabinet face.
Even with the pipe cut as short as I dared go, the cutout notch would have to be larger than I wanted. What else could be done? I wanted the joint to be removable for any future needs of removing both the fresh water cabinet pieces, or the galley cabinet pieces, for whatever reason. I concluded a longer pipe would have worked, simply by removing either face board, and that would prevent the need to cut the "swing up notch".
Within a few days, when I discuss some other waste water plumbing issues, you'll hear how I further altered the dinette (grey water) cabinet to allow it's removal without touching the fresh water cabinet. Likewise, here you see the fresh water cabinet removed, and that is without touching the dinette (grey water) cabinet.
And that allowed the joint, with the already shortened fresh water cabinet side piece shown here, to be inserted, even IF it were longer.
Next came the sweating.
I just heated the joints, moving around the pipe to try and heat evenly, then settled on one side as much as possible to touch solder on the far side. That causes the solder to flow toward the hotter torch side. The pipe was big enough that I couldn't just remain in one spot. I had to kind of work the heat, and the soldering point, around the pipe. Of course besides a good cleaning and burr removal, I had brushed on flux. Flux is absolutely necessary. It lets the solder flow.
This picture shows the completed unit - partly polished up.
More polished.
And in position.
A keen eye with see the poorly placed cabinet mounting screw. Yes, it was problematic. I'll discuss that later in "Galley".
Here's how the Fernco adapter connects to the shortened pipe. I don't love the rubber compression. But of course I chose the smaller copper outside diameter (than what the adapter is designed for - PVC larger diameter) for just that reason, it was smaller for the cabinet face constrictions, as I didn't want to notch the chrome flange on the range, plus the living area's look of the copper is better to my eye than would be PVC, painted or otherwise.
Also note the top of the face wall is leaning forward (left), away from the plumb line on the opposing wall. Therein lies the cause of the miss-measurement of the copper stub pipe.
And actually, that plumb line is too far backward (right) but the point is made.
There is a resolution however for the shortened stub pipe. I simply flipped the unit. The distance needed behind the range was much shorter than was the distance in the fresh water cabinet, for obvious build style reasons. Here's how it sits after flipping.
And here viewed from above through the access area below the fridge with the small under storage floor cover removed. Much better! I was very pleased.
Now a good plumber would say I've installed the "street elbows" backwards, and they would be correct. It's appropriate to discuss that here.
A "standard elbow" has two female ends. I know, I know - don't ask me to explain it, it just is and I accept it.
A "street elbow" on the other hand has both a female end, and a male end. Now that I say it, it seems even stranger. But here's why. (Some of this is truth, some is assumption and I'm making up the rest as I go - so you've been warned).
Even weirder is that a pipe has only two male ends! Therefore, any fitting that a pipe goes into has to be a female end. The beauty of a street elbow is two fold. The first and obvious is that you can put two fittings together, because each have a female and a male end. If I had used two standard elbows, I would at the least have needed to cut a 1.5" piece of pipe (called a nipple - I think maybe the original plumbing parts namers were somewhat Freudian) to sweat between the two elbows! By using the street elbows, I could insert one elbow right into the other, skipping nipples altogether.
Now I don't particularly like to skip nipples, but in the interest of the space and time continuum discussed yesterday, I am not against it.
The other reason, and of more particular importance, is that of correct placement of the female and male ends based on direction of drainage flow. Like a funnel, put the male end into the female end to allow a constriction free flow downstream for the waste, often containing much more than simple liquid.
This correct installation of a street elbow was considerably more important back in the day when plumbing materials had more wall thickness, such as clay pipe used throughout many cities. The female end had a sort of bevel on the "waste catch" edge, while the inserted male piece had a sharper squared off edge. Waste would flow better through a joint that had that bevel, and would catch on the squared edge of the male end (if it was installed backwards). The basic inside diameters were all the same, but there would be that little "catch" in each incorrect joint. The same is true today in something as commonly used as PVC. But the thinner wall of the copper, especially for a galley sink, is of much less concern, than otherwise.
And it fixed my "too short" boo-boo.
(Dave wipes the perspiration from his forehead), well, that was uncomfortable. Glad THAT's over.
