Here's a collection of my cleaned molding. The two hanging arched pieces are J mold or drip mold, found on the front and back roof line edges.
Their shapes changed to a covered wagon like arch as I hammered the screw holes flat.
Above those are some straight pieces that are the same material and are angle mold or L mold pieces found on most of the camper edges.
The drip mold was found only over the front and back walls. The edge above the driver and passenger doors are simply angle mold, so theoretically you get rain run-off right onto your head as you come and go from the truck cab. I think I'll change that.
Close ups of the drip mold.
Here are close ups of the angle mold.
And check out this cool technique - cut by hand it appears - to run the angle around a curved section of the camper (back wall - tailgate-opening trim near the tail light rounds).
You can still see some paint on some of those pieces; I'll complete cleaning prior to installation, but wanted to get it to where I could clearly see and manipulate it as I custom use it. I have plans to purchase extruded aluminum angle (rigid stuff) to use on the camper's straight runs, and to save my usable flexible (annealed?) original pieces for the rounded sections.
It started out much messier!
Here are some pics of stuff I didn't clean, but saved for potential use because it is more mangled than the rest.
You can see the two similar shaped pieces, with their bends - those are from the front camper box corners and are mostly right angles. I should be able to easily replace them with extruded angle, custom cut to fit.
I don't believe the trim does ANY sealing! That ain't its job. It is the butyl tape UNDER the trim that does the sealing. Of course sealing is what keeps out the water, not trim. So when people think they need to crank down tight on the screws to help the sealing, it simply distorts the trim, perhaps the metal (or whatever surface), starts to strip out the screw hole (wood, aluminum stud, etc.) and squeezes out the butyl tape. No - the job of the trim is to protect the butyl tape and secondly, to protect the structure corner from bangs and hits and to direct water runoff in the case of the drip mold. The butyl tape does the sealing and it is soft. It needs to be treated gently and if damaged the trim should be removed, the butyl replaced, and the protecting trim re-installed. Slopping caulking, especially silicon, over the trim and on it's edge just ain't gonna do it. A proper bead of the right caulking along the trim edge? Now that is proper! but it should be minimal and correct, not slopped.
Incidentily, it's been said before and I'll restate it here - DO NOT USE SILICON. It is only removed by scraping, and lots of it!
That's my conclusion and I'm sticking to it! :)
Anyway, here is a short trip through the cleaning process. I started out scraping the various types of butyl tape from the trim. I think the dark green stuff was original from the factory. I found it on most of the areas.
Note the distortion of the soft annealed stuff when tightening the screws. That was all hammered out flat.
The paint removal process enlisted the help of an old toothbrush, some "sprayable" paint remover (highly recommended), a brass bristled brush, and lots of patience, wetting application and patience. Did I mention patience?
At first I brushed on the remover (from the steel bowl) then moved on to the spray bottle (any pump spray bottle would work, but I used the one that came with the product when I ran out of the first can).
I finished up with a stainless steel bristled brush to burnish the aluminum.
These are my "save and reuse" pieces in various state of completion.
During this time I was Internet searching for a source to provide replacement molding, should I find I need more similar product. I know it's out there, but I couldn't find it. I have one more email out to an aluminum place for some answers, but no response yet. Not to worry, the trim install is still futuristic.
As I started to say, I'll use new, rigid extruded aluminum in most places, including places that never came with trim where there are non-original holes in the sheet metal to rectify. Then I'll use my flexible stuff (even the straight runs) on the curved and rounded places as needed. I'll be turning some of it into J trim over the truck doors. I'll be reshaping as needed. I'll probably head over to Harbor Freight for a cheap metal brake for clean bends.
I think originally this stuff came flat on a roll and was shaped at the factory by a rolling press and cut to length. I think it is still available in the world, but I cannot find the application (no longer used on today's RVs) and I don't know the right words to search. That's why I've been placing a question mark after the word annealed.
Later, when I talk about the roof metal, you'll see how I plan to double up the stuff - an angle AND a drip mold - in places.
One more thought. I found NAPTHA the best solvent for the butyl tape. Applied and reapplied two or three times (keeping it wet), brushed with a toothbrush, or rubbed with a rag, wiped clean with some of my previously used paper towels, really did the trick.
Now I'm a lacquer thinner kind of guy. Okay, okay brake cleaner in some situations, but lacquer thinner is my go to. Of course mineral spirits is on the shelf too. And recently I got some acetone because you always hear people talk about using it (to clean the surface before applying new sealer or whatever). When I was a kid, we called everything "paint thinner". But these are all different - slightly or greatly.
Now I'm no chemist, but I did take chemistry in 8th grade and I've been ingesting chemicals my whole life, thanks to Monsanto and others, and I went so far as to buy a periodic table school-size wall hanging when I was in my teens (that was before Metallica posters) so I figured I have the RIGHT to conclude chemistry issues - right or wrong.
Lacquer thinner wouldn't touch this stuff. Acetone wouldn't touch this stuff. Mineral spirits wouldn't touch this stuff. Naptha is a little oilier and less evaporative than those others. DS left me six quarts after a job he did, so I had it, I tried it, I liked it. It did a great job on the butyl and even better - it softens Silicon!
Yes, you heard me, "Naptha softens Silicon", tell it to the world! Instead of scraping hard rubber like silicon, I was able to scrape layers off softened silicon with Naptha. Try it next time you come across the evil stuff.
