Dave_Pete
Mar 06, 2017Explorer II
Today is Labels. Here's the collection. With the exception of the bottom row (water tags are non-original), Lil' Queeny's tags are on the right, and the Travel Queen parts camper's are on the left.
Top row includes the California State mobile home housing compliance tags (green), which include serial number, etc. Its data duplicates a factory worker stamped tag (probably during construction for identification of an individual camper prior to the arrival of the official State tag) and those are shown to the sides of the State tags.
Second row is 120 Volt electric, third row low voltage electric, and fourth row is the LPG warning. Notice the faded condition of the LPG, to be discussed later.
How do you prep or restore these things? Leave them untouched to retain all aging and patina? Buff them up silly and repaint? Well for me, it isn't about retaining some sort of monetary value, it's more about making them functional for their original purpose (readable and warnings in logical places and where they make sense), clean them to a point that they look "maintained" or cared for, like the rest of the camper, and just have fun with it!
So that means steel wool, and a light touch.
Here are the entry assist handle, and the State tag for Lil' Queeny, getting back to their original spots in existing sheet metal holes.
With a dab of butyl tape on the threads, that's all these items get.
I think the M is for Manufacture number, not Model. The S 7874 must be serial number, although I haven't been able to figure out a rhyme or reason on the numbering in comparison to quite a few other Travel Queens of known years.
The 3443 is prefaced on the factory stamped tag with a PA and then an I at the bottom. What is PA? Is I a factory ID? Note J on the other.
The factory stamped tag was found at the entry door, bottom left corner. On the parts camper, the tag was in the same proximity, and it has a J instead of an I. In house manufacturer number perhaps?
And what is the DA 195334 at the bottom of the green State tag? State department or office number? And the remaining spaces on the State tag indicate compliance X's with Propane/Liquid Gas (PLG), Heating (HTG), and Electric (EL).
Here's how they made the stamped tags in the factory, grab an extra of these and turn it over.
I didn't want my factory stamped ID tag outside, next to the bottom of the door - I would have had to drill new holes in new sheet metal, the color band no less.
Instead, I took a modern twist, where they put tags inside a kitchen cabinet, and using an original hole from the breaker box (top left), and on a piece of original plastic laminate used in the original stove surround I had left alone inside this end wall for exhibition purposes, I installed my ID tag here.
I found no original tag at the water gravity fill or city water hookup. And the low voltage was mid-ship just above the wall edge where the connection was located just under the wing.
But I moved it down near the new actual connection.
Yeah, when loaded, you won't see it. But functional right? And at least I'll know it's there, and that's all that matters. ;)
Lil' Queeny's new 120 Voltage location.
Yup, new holes. This whole "hook-ups" region is a combination of old and new, but mostly new in expanded old places (original, existing sheet metal openings and label screw holes), especially on layout.
And then because the new water tags were different (bolder font, black not red, two screw holes not four), I treated them differently in their installation. With a sort of thinking that the red warnings, are a different thing than the black "informative", if you can see the thought process.
So, no new holes in the metal.
City Water (Connection).
And Gravity Fill (Supply).
And of course, the sanitizing warning fit appropriately on the water supply tank system, all in logical locations, and inside the door is a bit of protection for the adhesive decal, while still appearing to be a metal plate like the others.
And then the LPG warning label. Its red lettering had faded the worst. I spray painted the label red, let it dry a few minutes, then carefully washed the surface with a lacquer thinner dampened rag. It left a prettier and more readable red lettering. Here it is after, compared to before in this post's first photo.
I didn't like it above the tank compartment, not the most functional as it's too high there to read for most people, and secondly, it is blocked when the door is open, right when you need to heed its warning. So I put it down low in the metal below the color band, like labels on the other side.
And here is the overall effect. I think final placements leave a comfortable visual that adds to the look, without distraction or detraction.
And one last thing. Above the lower fridge vent, which used to be a slightly shorter propane tank cabinet, there are two label holes vacant in the sheet metal. I'm now wishing I had filled them, but I will put in two screws as plugs for now.
Those two holes are the original LPG tag's top holes, as the two lower holes were absorbed into the taller cabinet opening. I'd like to find an appropriate "Extinguish your Pilot Lights" metal tag to place there, as the fridge pilot will normally be operating, and the spot is right next to the truck fueling area. That sort of tag would be quite an appropriate way to fill those remaining holes.
