Dave_Pete
Mar 04, 2018Explorer II
Today: Outdoor Living - including the Awning, the Patio and Chairs, and the Entry Steps
This Resto-Mod is winding down. After this, I think one more, a "Before and After" of both the interior and exterior, and that will close out the entire project.
In our much roomier 2013 29' Komfort TT, we have a single slide-out. It held the sofa, a two-seater that came originally with an under drawer and a weak build. Scrap hardwood - of odd dimension - and we found ourselves tilting toward each other as we sat, getting sore butt and thighs as we subconsciously muscle propped up one side of our body over the other, in an effort to get comfortable and see straight on, as opposed to views at a tilt. The fancy-named dinette (I forget the marketing term, but it had one) was even worse!
If there's one thing more uncomfortable than a normal flat seat and back, u-shape dinette with thin cushions, it's an odd build of the same, made to look luxurious, but it ain't. That happens a lot in the newer units, at least in the entry level pricing - and one step above, like we thought we were getting at IT'S price range.
Both the dinette and the love-seat came out, and were replaced with a drop leaf table for two to four (more surface than the original dinette table) and two nice dining room chairs (matching to the set in our home) and a wall-hugger, two place recliner. Comfy! The weight difference was negligible, but turned the TT into a two sleeper only.
Would we find that comfort in Lil' Queeny? Are we already "spoilt". Remains to be seen. I'm sure more than one reader has wondered through our process if we would find the tiny home too tiny - something (tiny homes) developed mostly by Millenials as they try and find ways to move out of their parent's homes, or as they try and bring wisdom into a society seemingly in a spiral dive due to over-consumption and wastefulness in our world.
But for years now, we've already traveled "thousands of miles" in our little camper, right there in the garage. Remember the beer-thirties? Much of THAT was on plywood, without the cushions!
So there will be a learning curve no doubt - that is to say while trying to be comfortable while out and about, especially as we travel through areas of poor weather.
We can always get comfy in the truck seat. That 2006 Dodge Ram is one of the most comfortable front seating arrangements I've ever had! And we've outfitted the dinette to act as a slightly reclining lounge. So we got that going for us! Which is good.
But most of our comfort expectations involve sitting outside, when we ain't walking around, and that has taken on a number of sitting arrangement potentials.
Our first awning experience was on an old Class C Mini-Winnie. We fell in love with having an awning. Never had one on the pop-up Starcraft TC. The one on the TT is big, and high. The higher they get, the more area you need for the same amount of shade.
And what about Lil' Queeny? Well you already saw the awning rail, mounted just below the dinette window. Low enough to reach, but requiring a bit-o-duck when approaching. I had thought about a 8' by 8' or so, but that would require outer supports and guy-lines staked out. What else? Self supporting? Easy to put up and down - and to stow? So we ended up with this.
And the comfy chairs we like. :)
And an L shape for the patio rugs - taken from the TT storage, cut in half (careful now, that stuff loves to un-ravel) and the cut edge sewn with a front and a back-side nylon strap.
Come back from a hike, remove shoes and set them at a corner, pop a top and walk around in bare-foot or sock-foot comfort back at the ranch - err camper.
Parked at the right angle, it offers plenty of shade - which is its main purpose - not to mention cover from a light (or heavier) rain.
We chose this fabric. And we love it. Tough, UV protection both sides, easy to work.
And did I mention it's self supporting?
Here's how I did it.
I started with these pieces of 1/2" electrical conduit fittings I had on hand.
Some were new purchase, originally intended for Tow-Mater and his light switch planned for the front entry. Some were used, and came with the 6 place dog-kennel we bought years ago from the neighbor for DW's enclosed garden. I removed the un-needed conduit, which was in place to power outlets for the winter-heated water dishes for the neighbor's sled-dog team.
Notice front and center, I cut off an elbow end, compare to the one behind it.
Doing the other.
Then the part is fastened to the bottom hole of the curb-side jack corners with a short bolt and nylon lock nut.
And the compression adapter is installed onto the 4.5' long section of conduit (awning struts), then fastened tight to the fitting, which always remains on the camper corner (the fitting, not the strut).
Both sides. Those (struts) are installed (screwed in) while angled downward (for ease against the force of gravity - dang science, moves into every thought these days!), and then lifted to where needed for set-up completion.
The awning fabric is rolled around the outer rod (the awning head rod) and stowed. When deploying, the awning edge is drawn into the wall channel, then rolled out, almost reaching the ground.
Then you string the awning out away from the camper, insert one, and then the other struts, into the elbows, like this.
And the set-screw to the strut is tightened. I might get a couple wing-screws. The other set-screws remain permanently tightened onto the head rod.
And that creates this sort of self-supporting angle.
You take it down the same way, rolling the struts up with the rest of the package, and slide it all nice and neat into the draw-string bag I made out of the same material.
In turn, it rides in those hooks meant for Saf-T-Jacks parts, spread a little to allow a tight wedge-like fit, then small cord bungeed onto both. I also added a third support, and bungee, in the middle to control bounce.
Incidentally, I bowed (bent) the head-rod outward, in relation to the elbows, so as to take up slack in the center of the awning fabric. Worked nice.
And the conduit provides enough weight to hold itself down in light wind or breezes. For anything more than that, we have some corner weights planned that will hang on the ends of the head rod. These will hold citronella candles in a can, built to the necessary weight desired and stowed likely in the grey water access.
The stairs...
Fold up and stow like this.
While the rugs and chairs stow here.
This awning is the "42 Degrees North" style, meaning the winter time sun angle, while facing south, will cast a shadow across your upper chest. (Unless you are a Flat-Earther - then you have to come up with your own theories on where the shadow lies).
And at that angle, you get the winter time sun warming your body, while your face and eyes are shaded. Any further south, or anytime closer to Summer Solstice, and you'll get the increasing shade you need.
And that my friends, makes for some needed outdoors comfort.
Doing the other.
The stairs...
