Dave_Pete's avatar
Dave_Pete
Explorer II
Nov 12, 2014
1968 Travel Queen Resto Mod - 7. Finishes & Finishing
I've reached a point in our Resto-Mod where it has come time to start applying finishes. On new wood these will be in the form of primer and various paints, perhaps some stains - and poly, lots of poly. On old wood, particularly the interior birch paneling, it will consist of stains and once again, lots of poly. I'll talk about poly and color schemes in a minute.
But this thread is about more than those things mentioned above. All the little elements of completing this camper that don't fit elsewhere into logical categories will end up here. In fact, the very last posts for the entire build will probably be toward the end of this thread, even though there will, of necessity, come several more parts after this Part 7.
Here's a complete list.
1968 Travel Queen Resto Mod - 1. Acquisition & Evaluation
1968 Travel Queen Resto Mod - 2. Dismantling and Salvage
1968 Travel Queen Resto Mod - 3. Structure and New Wood
1968 Travel Queen Resto Mod - 4. Bathroom Remodel
1968 Travel Queen Resto Mod - 5. Propane
1968 Travel Queen Resto Mod - 6. Jacks & Tiedowns
1968 Travel Queen Resto Mod - 8. Fresh Water
1968 Travel Queen Resto Mod - 9. Electrical (AC/DC)
1968 Travel Queen Resto Mod - 10. Galley & Greatroom
1968 Travel Queen Resto Mod - 11. Night Chamber
1968 Travel Queen Resto Mod - 12. Waste Water
1968 Travel Queen Resto Mod - 13. Exterior, Skin & Openings
1968 Travel Queen Resto Mod - 14. Viewer Perceptions
By poly, I mean polyurethane. My wife and I have a love affair with polyurethane.
Back in the mid-nineties we installed our first hardwood floor in our home, a combo dining/entry room that has since become our front door foyer. We used unfinished 3/4" red oak boards. What a learning experience. As novices's we didn't realize the rented floor sander was broken, we just thought it was inadequate, so most of the sanding on that floor was done on my knees with a belt sander! And it turned out beautiful, but OMG! After staining we put down a floor grade (thick) high-gloss polyurethane, and we've never looked back!
We still use flat or eggshell finish on ceilings, and will entertain combinations of satin, or more likely semi-gloss on walls but EVERYTHING else gets gloss or high gloss. And we've done lots of custom/craftsmen woodwork in our homes (I say homes because we flipped one in Fairbanks when we had to move there for three years), and ALL those wood stained surfaces get high-gloss poly!
We've always been "earth-tones" kind of people and for years we kind of went along with the crowd that basically stated home walls should be pretty much neutral and of lighter colors. Meanwhile, many in younger generations were coming in with black and rich primary colors for entire rooms and as a traditionalist I just kind of shook my head.
Then we did a little more of something on the house exterior and we liked it. Then we moved to Alaska and DW had her OWN epiphany on color palette. I was at work so she just did it while I wasn't there and I had no choice (just kidding - she involved me). But like always, her interior decorating was right on the money; she really has an eye.
In essence we moved into darker, richer colors. We don't do white. Cream or off-whites are okay, but we avoid white. We don't do black, but many of our darker color choices are going to look black at first glance. We use lots of copper, expresso, reddish tinged golden stains, all along with the original earth tones, but which have become somewhat darker and richer themselves. In fact, we liked the end results so much that upon our return to Wyoming we changed up our long-term home to much the same colors as we had in Fairbanks. So that's where we're also going in the camper!
I know, I know, the traditionalists are going to say, "You have to keep the colors light in the camper, otherwise it will feel smaller, closed in!" Perhaps, but we'll see won't we. ;)
  • One of our first finishes to go on was the white - you know, the white we said we don't do?
    This white is primer and it is pretty intense! It's a "zero" something or other and is supposed to be a stain and odor blocker like Kilz. DW bought it for some other project we haven't yet gotten to and we still had a full gallon. It is water-base but it's not at all like these latex house paints that if they dry on your plastic roller pan you can still get it wet and peel it all off. Oh no, this stuff seems to now be a permanent part of my pan, not to mention my fingers - in spots. It's a really tough sticking primer.
    I covered all surfaces of both wing assemblies, the bathroom basement surfaces (the under shower pan compartment), the interior surface of the left rear wall panel, and the plywood edges of both back wall panels. Initially I wanted to leave the bathroom walls unfinished for application of another substance, but I am now considering priming those surfaces as well because of the terrific adhesion of this primer over the sanded and smoothed original surfaces of most of the bathroom wall.
    Just prior to priming I had been looking over the interior paneling, experimenting with some sanding and getting together a plan for finishing the woodwork. Part of the reason for that now is to prepare the partially damaged panel edges to receive the back wall panels, and the other edges to receive the wing assemblies, etc. Another reason for the plan on the interior wood finishing is to perhaps DO IT before closing up the camper. Each of these decisions delays the assembly process, but I'm starting to feel it will greatly increase the completion process once assembly DOES begin to take place.
    The next few days will be work on the actual interior woodwork and panels!
  • 67avion - What is your countertop? Looks interestingly like something we are considering.
    Wagonqueen - your disco ball comment elicited quite a laugh out of DW. Our original accents (stove/oven color, upholstered band across bed, plexiglass window between cabover and dinette) are also the avocado/60s-70s green. I want to try and paint the back side of the original faux woodgrain refrigerator panel an avocado green to match the range. Going to try some appliance enamel to attempt to get that hard smooth shiny type finish.
  • Oh yeah! Great colors. And thanks for the validation. The deep colors are very nice.
  • We did the "cherry" (dark) with all the wood, so we decided "lite" gray and white to keep things lightened up.(and normally I don't do white) It seemed to fit the color scheme I was going for. More of a "MOD" with hints of 70's retro (green). Still haven't got all my hints hung yet... but there is plenty of time for decorating. Just have to find which corner I will place the disco ball I just got before it breaks. Can't wait to see your choices. Love when a good vintage renovation comes together.
    Whelp, I don't think I'm a "traditionalist" nor do I belong to the vintage police. But, I do love the old fashioned look of the wooden interiors. We sure used a lot of poly and wood tones in our Avion.
