rockychancegirl wrote:
Thank you all for the welcome. I'll check on the Avion camper rebuild as I found more of what appears to be water damage; some old, some new. I couldn't upload more than 1 picture to my original post so will work on that. I stayed on back roads going home so I could go slower but fewer opportunities to pull over. Once I got to a 4-lane the ride was much better for me (no more sway) and for the people behind me.
I looked all through the camper and found a lot of storage space so I don't know if a water tank was removed or it really never had one. The water heater needs to be lit once it's filled and (I thought) drained and shut off if I'm not using it for any length of time. I don't know anyone with a truck camper so this is where I'm looking for the knowledge base.
How do I determine whether the frame can handle a reconfiguration to 4 legs vice 3?
if you want to go to corner jacks it may be secure enough to hold the weight.... i know with the three bottom mounted jacks on mine the framing on the single side used 1/4 inch plywood on the inside..plus i bet the water tank was on the floor inside a cabinet at the front of camper it may have rusted or froze so got removed..couple of other memebers have gone to corner jacks hopefully they will chime in..
