donkur's avatar
donkur
1971 Scamper Trailer Manual or water tank help
Hi. Reading through this forum, it looks like there is no manual to be found for my 1971 Scamper Trailer. I just got it earlier this month and it is beautiful. Laminated cupboards, beautiful curtains... The water does not work though, it almost seems plugged at the tank. I was going to siphon the tank but I cannot get a hose down there from the outside. Then I noticed a small hose under the trailer that is coming down from the trailer. Looks like it is from the tank above. Wondering if there is some kind of a tap or a release to drain the water from the tank so I can pinpoint why I am not getting water. Hoping to drain the tank first so my trailer does not flooded.
Thanks in advance – I am hoping.
  • The hose coming down from the tank is actually the overflow because it is coming out of the top of the tank down through the floor. I ended up cutting one of the hoses out of the tank to try to siphon it but I didn't have any luck with that. I did however find that someone I'm not sure who, maybe the trailer came like this but there was a hole drilled through the floor wide enough to fit the hose so I guess that's how people have been dreaming the tank in the past. Water is draining through there now, will replace the faucet after I run a new hose throughout the trailer.
  • Look around all sides of the fresh water tank. If the pipe you saw from underneath is a tank drain, there will be a valve very close to the tank. Also, your water pump will be in that area. That will be the place to start trouble shooting. If you have a winterization line, connected between the tank and pump, make sure that the valve is in the correct position (try both directions with the pump running and sufficient water in-the tank). If it pumps water from the tank, good, if not start with pump clean strainer, obstruction diaphragm etc. Then down the output line to fixtures.
    Ken
