Bob Whalen left a message on the blog that he would send me some pics of a two tank system he installed under his Amerigo. I promised David McQuaid I'd post them when I got them. Here they are David. Bob, many thanks from all of the Amerigo owners interested in your setup.
Below is Bob's quote from email about the setup.
The pics show the 2 new tanks installed . the black water is a17 gal and the gray water is a 23 gal.
"The new black water tank discharge does not center on the factory cutout , but I will reshape it.
The gray water discharge is just behind the bracket for the stairs.
The inlet for the gray water does go through the side of the tank so you will not get the full capacity of the tank.
I also installed a fiberglass sheet over the plywood before installing the tanks as this area is exposed to the weather when driving.
It took longer to put the toilet back in than it took to re-plumb the tanks."
Bob sent the email for the tank website, but it didn't come through. I've emailed him back for tha information. Carey
