Hi Guys,
Saw your post and thought I'd chime in....
The two plug connectors up front are: the small plug was for an intercomm between the cab and camper. (I don't let my kids in the back when traveling, so that was removed, must have been a 70's thing)
The other plug, as you know, are the running lights/brake/turn/12V/GND. If you add a battery in the camper, make sure you are getting 13 volts or more to charge it while driving.
Not sure what Romex wire you're talking about from the converter. My converter has stranded 12 or 14 ga wires for the 12 volt system. The Romex is only for 115/120VAC outlets on mine. Come to think of it, the line you're seeing may be the wire for the Airconditioner. They did pre wire some of these that way...
I'm going to be loading up mine tonight. I'm adding another flat sceen/DVD combo to the Snap n Nap. An articulating arm mount to the wall against the bathroom. I also want to add a removable shelf from that same wall to the Snap n Nap back. This will be for my son's duffle bag to get off the bed area.
We're off to Myrtle Beach Sunday morning for 10 days so I'll be busy packing..
Keep up the hard work rebuilding.....you'll enjoy it when it's done!!
