johnvosh
Aug 19, 2020Explorer
So for the 12 Volt system in my trailer, I am hopefully going to rewire it so that it is spread across more fuses instead of just 3.
1) Furnace fan -> 5 amp
2) Fridge -> 15 amp (probably will never use on 12v)
3) Range hood/light -> 5 amp
4) All lights -> 10 amp
5) Fresh water pump -> 10 amp
6) 2x 12v fans -> 5-10 amp (put by bed to move air around inside)
I do have a question about the cable from my battery. I had to run new cables from the battery to the inside of the trailer. I ran 10 gauge stranded wire, what size fuse do I need on this cable? Thanks!
