COChuckExplorerJul 02, 20161983 Coleman WilliamsburgI have a 1983 Williamsburg popup. I am refurbishing the unit. I think I may have blown the fuse for the tail lights. Any idea where the fuse is located? Thanks
Artum_SnowbirdExplorerJul 02, 2016I have fixed a lot of tail lights in my day. Generally, there is a better chance that you have lost the ground connection to the tail lights. The way to check that is to connect the side of the bulb fixture to a good solid ground, like the negative from your battery via a jumper cable.If the bulb works now, it is the ground connection, not the power going out to the bulb.
Related ContentWilliamsburg, VAColemanColeman 17BWilliamsburg/LangleyUser Manual for Fleetwood/Coleman Williamsburg Tent Trailer?
