- tattoobobExplorerI had an "86" Real-Lite, it had water problems when I bought it the roof was leaking because of neglect I repaired it and kept it over 20 years, It's a 34 yo camper there are going to be problems
I hated to sell it it was the biggest one they made at the time (1200) I really miss the dry bath and the side entrance
To answer the question it is a wood frame camper - SidecarFlipExplorer III
Troutguy wrote:
midnightsadie wrote:
x2 look around the ceiling for water marks. if none and you like it buy it. its 34yrs old theres gonna be some problems ,BUT a 2017 of the lot has problems. first thing new tires ,tires rot no matter where there stored.
TIRES? Truck campers don't have them.......trucks do! You may want to restrict your comments to the relevant forum.........;)
Some did, way back when....
You could get a big camper with a tag axle underneath. - TroutguyExplorer
TIRES? Truck campers don't have them.......trucks do! You may want to restrict your comments to the relevant forum.........;) - SidecarFlipExplorer IIIStated before in your other thread that Real Lites had issues. Water intrusion issues to be exact. I also said that I've posted on here in various threads what to look for and where.
Could be an 1100 buck 500 hour rebuild job or could be ok. I lean toward the rebuild. 34 years is ancient and you live in an area of extreme weather (I live in Michigan as well) so if the unit was outside and the OE didn't stay up on seals and caulk, it's most likely a leaker and rotter. They have wood frames btw.
Always best to store any TC inside during long periods of non use. I do.
You may find it's even worse that the Palomino and unlike the Palomino, there is more camper, thus more rebuild. - LwiddisNomad IIIInspect closely. If good buy it...$1,100 isn't much..22 nights camping and you are more than whole.
- midnightsadieExplorer IIx2 look around the ceiling for water marks. if none and you like it buy it. its 34yrs old theres gonna be some problems ,BUT a 2017 of the lot has problems. first thing new tires ,tires rot no matter where there stored.
- BlissRamblynExplorer
donn0128 wrote:
Build quality on a 34 year old camper? Worry about leaks. The rest is not worth worrying over
Someone brought it up on this forum. Just trying to figure out if there are any issues that will pop up before I buy it.
And Id like to determine the frame material. - donn0128Explorer IIBuild quality on a 34 year old camper? Worry about leaks. The rest is not worth worrying over
44,066 PostsLatest Activity: May 13, 2026
