spike99
Oct 09, 2013Explorer
You are correct. Rollers and bars under RV's rear to stop it from bottoming out is very bad. Especially across the deep bumps. re: Risk of bent frame waiting to happen!
To resolve, simply re-position the axle(s) BELOW the existing leaf spring packs. To determine axle perch /saddle size, simply measure axle diameter using short thick wire - like Calipers. Then, hold the distance gap against a tape measure. Thus, confirming if 3" axle or 2 3/8" axle.
