ajcal225
Dec 06, 2013Explorer
Desertboy wrote:
Welcome, And for $500 ? No you didn't get hurt at all. The AC on the roof is worth that, So everything else down below was free.
Yes, I don't feel bad about it at all. I found a book of invoices from service and repair up to just a couple of years ago; this was somebody's baby and well taken care of for a long time.
I have most of the interior stripped out right now and every panel that isnt nailed or stapled in place, is now in my garage. While I have it apart, I'm going to replace the running lights with LED's (I have to replace one of the tail lights anyways), add a few 12v plugs and some 5v usb plugs, replace the insulation that is there and add a lot more, before re-assembly. I'm also going to replace the 6 pin truck harness plug at the front with a standard 7 pin closer to the rear, so I don't have to drill a hole in my bed to add an outlet. I don't know at this time if I'm OK with running a 'Y' cable off of the factory trailer plug to the camper and trailer, or if I should add a second outlet next to the first.. but I don't need to worry about that for a couple of weeks.
